tdm850 carb differences
6 replies to this topic
#1 mrtee
mrtee
  • 9 posts
Posted 06 March 2008 - 08:30 pm
hi,
I have a tdm850, its a 2000 reg with digital odometer. I understand the carbs are different to the 1996-8 tdm850? So a dynojet kit from an earlier model will not work?
Thanks.
#2 mrtee
mrtee
  • 9 posts
Posted 08 March 2008 - 12:42 pm
Anyone got any ideas?
#3 Hawmaw
Posted 08 March 2008 - 01:33 pm
Why not contact dynojet and find out.
I've got a mk1 so I don't know the answer. Sorry
#4 Guest_erdferkel_*
Guest_erdferkel_*
Posted 08 March 2008 - 02:31 pm
hello,
i don't know, if there are differences in main or idle jet sizes. But i do know, that the needles (those that wear out the emulsion tubes) are easily replaceable on the MKII carbs, but pressed in on the MKIIa. They can be replaced, but supposedly not without special knowledge and/or tools.
I'd chime in with the advice to contact dynojet or mikuni.
good luck
Glückauf
ralf
pig, MKII
#5 Chris TDM
Chris TDM
  • 328 posts
Posted 10 March 2008 - 09:20 pm
Basicly if i remember right the diffrerenes are
Pilot screw settings
Fuel levels
Jet's
after a date (1998?) they changed the carb models which changed the emulsion tubes to a pressed type (so you cant change them) Also the carb size got bigger (40mm up to 42mm?)
i think a pre 99 dynojet kit will work, but not as well as a 99 onwards kit
Ridgeway mcc
GSF400
ER500
TDM850
CBR1100xx
But only one working at a time!!
#6 JBX
Posted 10 March 2008 - 11:04 pm
I just added a page to my site about TDM carbs characteristics.
There are some difference between 1996-1998 & 1999-2001 carbs.
#7 Studley Ramrod
Posted 20 March 2008 - 09:43 am
I bought some 4TX 00 year carbs and fitted them onto my 94 3VD.
Straight swap and bike fired up lovely, ticking over smooth and not a blip or splutter ! There's a sudden loss of revs on throttle roll-off and above 5000rpm she's flat. Also, she's running rich...I think !
I'm pretty sure the needles are longer in the 00 carbs than the earlier 'uns, which may make a difference when fitted the Kit.
The 00's are definitely longer than the aftermarked needles I took out of mine...about 8-9mm.
The 00's are definitely longer than the new standard needles for my 3VD...about 5mm.
Main jets are different sizes, not looked at any other jets etc yet.
Edited by Studley Ramrod, 20 March 2008 - 09:49 am.
