Lean - White Spark Plugs - Aftermarket Exhaust
13 replies to this topic
#1 Lithil
Lithil
  • 8 posts
Posted 17 July 2024 - 09:56 pm
Hello fellow riders,
new to the forum, thanks for validating.
I bought a time ago TDM 850 4TX (2001 year) - latest model on Europe market. I drove bike first few tousands kilometers and realized my bike smells of fuel. I swapped aftermarket exhaust (more open cans) and bike started to be more alive and started heavily popping on decceleration only - thought when bike runs better, no issue. After time i have checked spark plugs - one white, one totaly black - i thought there is an issue in carb (bike was poorly maintained by prevoius owner). I have rebuild carbs (MK2a carbs - Mikuni BDSR38), including new needle jets pressed out and new needles. Cleaned spark plugs and after 50km checked - both white (one maybe slightly, veeery slight starting tan color). Decceleration popping is same, performance same except thorttle is smoother.
And now question - what would you do to improve mixture and how to spot good mixture at best ?
I hope i explained story of my bike well. My english is learned only from hearing and reading, sorry for that.
PS: valves clearance not done, tried to measure, but stripped water flange screw head .... peep
Thank you in advance
#2 fixitsan
  • 4,755 posts
Posted 18 July 2024 - 07:02 am
Are the carb rubbers leaking air through cracks ?
#3 Lithil
Lithil
  • 8 posts
Posted 18 July 2024 - 12:38 pm
Carb rubbers completely new - gaskets, mambranes and joints carb/intake. Same before as after
Edited by Lithil, 18 July 2024 - 12:38 pm.
#4 fixitsan
  • 4,755 posts
Posted 18 July 2024 - 01:51 pm
All good ?
You have to consider the carbs then. Have you ever modified a needle ? If you can figure out where it's at it's most lean it might be a case of marking the needle and rubbing it down in that area. But a new needle/jet would be better
#5 Lithil
Lithil
  • 8 posts
Posted 18 July 2024 - 02:39 pm
As i wrote above. There is completely new needle and needle jet. 5 days ago exchanged. Carbs serviced. The lean condition is same before and after carbs service.
#6 Catteeclan
  • 2,484 posts
Posted 18 July 2024 - 04:43 pm
Is the bike riding ok or are you chasing the popping on overrun?
#7 Lithil
Lithil
  • 8 posts
Posted 18 July 2024 - 06:26 pm
riding is good - its my first bike, so i do not recognise some slight power loss. But i think reponse from throttle could be better. Popping is smaller issue than white spark plugs
#8 dapleb
  • 18,193 posts
Posted 18 July 2024 - 06:47 pm
What brand emulsion tubes and needles did you use?
#9 fixitsan
  • 4,755 posts
Posted 18 July 2024 - 07:20 pm
OK thanks, I'm assuming you've checked the plug types are the exact type recommended ?
And also keeping in mind the known existence of fakes of every manufacturer's spark plugs.
NGK's website recommends the DPR8EA-9 (as does owner's manual).
Edited by fixitsan, 18 July 2024 - 07:23 pm.
#10 Lithil
Lithil
  • 8 posts
Posted 18 July 2024 - 07:24 pm
Mikuni original, replaced at Topham-Mikuni workshop in Germany.
to fixitsan: Spark plugs are replaced 2k km ago by me for DPR8EA-9 from reputable dealer (i do not know if they can fake it), but i have pair of new ones on table prepared in need .
#11 Lithil
Lithil
  • 8 posts
Posted 19 July 2024 - 06:22 pm
Today added on mixture screws +0.5 turns. No effect.
Thinking two options:
1. valves are out of tolerances or chain is sadly worn
2. aftermarket exhaust allows more air to be sucked back in to process, so i need to:
                                           a) give more turns on mixture screw
                                           b) put needles on higher position to allow more fuel flow
Your thoughts ?
#12 Catteeclan
  • 2,484 posts
Posted 20 July 2024 - 08:04 am
Mixture screw will only richen tick over and a little above. Think I'd restrict the air coming in to see if it improves the engine response.
Could always check the valve clearances and timing to rule them out.
#13 fixitsan
  • 4,755 posts
Posted 20 July 2024 - 10:08 am
Your thoughts ?
Option B worth trying
#14 leehenty
  • 5,145 posts
Posted 20 July 2024 - 04:23 pm
I agree raise the needles a notch, if still too weak at max needle height you might have to go up a size on the main jet
Edited by leehenty, 20 July 2024 - 04:25 pm.
