Clock Reset And Temp Gauge
5 replies to this topic
#1 Fenestrom
Fenestrom
  • 12 posts
Posted 05 August 2024 - 09:42 am
 2005 TDM900
Weird intrument issues
a) Clock shows running hours not time of day and resets to 1.00 every so often
b)Temperature gauge works fine when engine running but when ignition switch is turned off stays at last running temp. This will then drop back to normal when engine has cooled and igtition switch turned on again
Any ideas or inspiration anyone?
There is no Cloud, it's merely someone else's computer.
#2 leehenty
  • 5,137 posts
Posted 05 August 2024 - 10:14 am
Low battery, it resets on starting load dropping voltage low
#3 trevini
trevini
  • 1,815 posts
Posted 05 August 2024 - 10:30 am
What Lee said above. Might also be worth checking you CO settings too as they can do funny things if the battery voltage drops too low when cranking.
#4 fixitsan
  • 4,740 posts
Posted 06 August 2024 - 06:10 am
+1
A low battery can't provide enough current to start the engine and keep the digital dash alive while cranking
#5 Fenestrom
Fenestrom
  • 12 posts
Posted 07 August 2024 - 06:47 pm
Many thanks for the responses, sorry I didn't respond earlier as I got called away to an emergency job 10 minutes after opening post.
New battery time calls then.
Lets see if that sorts the temp gauge out as well.
#6 Catteeclan
  • 2,480 posts
Posted 08 August 2024 - 06:34 am
Got to admit to thinking there's something wrong with the dash not shutting down draining the battery. Fingers crossed.
