S111Tdm
4 replies to this topic
#1 AliG
  • 1,454 posts
Posted 03 July 2024 - 08:29 am
Both my TDMs are being registered in Spain so I retained the personalised plates. One has already gone but the other is now available. It is on a retention certificate so available for immediate transfer - £250.
Ali
#2 dablik
  • 10,820 posts
Posted 04 July 2024 - 07:03 am
Ali do you require a COC certificate of conformity to register in Spain ? and if so have you managed to obtain one from Yamaha or had to go through 3rd party..
#3 AliG
  • 1,454 posts
Posted 06 July 2024 - 10:13 am
I'm working through a 3rd party to avoid this.
#4 dablik
  • 10,820 posts
Posted 07 July 2024 - 07:18 am
Hm have to research this a little more in that case, cheers.
#5 leehenty
  • 5,159 posts
Posted 10 August 2024 - 03:26 pm
Mine
