Whinning From Left Hand Side Of Engine
3 replies to this topic
#1 TKH
  • 2,201 posts
Posted 04 November 2024 - 10:02 pm
Hi all
I've got my ninner off the road at the mo to fix a number of problems first one being that I've got a whinning from the left hand side of the engine when riding. It appears to be coming from the lower engine casing. Problem is I can't get in closer to have a better listen and now it's off the road I can't give very detailed feedback.
My initial thoughts were something in the small sprocket area. If so how and what would I check.
Ta
Edited by TKH, 04 November 2024 - 10:05 pm.
#2 Snowbird
  • 1,401 posts
Posted 05 November 2024 - 09:10 am
Hows the chain tension? They run fairly loose.
#3 leehenty
  • 5,154 posts
Posted 05 November 2024 - 09:46 am
Chain too tight, 50-60mm slack with bike on sidestand
#4 TKH
  • 2,201 posts
Posted 05 November 2024 - 10:25 pm
Snowbird/Lee thanks guys, yes running about 50 to 55mm. I check it regularly when on the road.
I think it was run too tight for a short while some time ago. Literally 2 to 3 miles.
