900 Air Box Mod....fantastic!
312 replies to this topic
#61 tdm850rider
Posted 02 December 2006 - 05:46 pm
QUOTE(dandywarhol @ Sat 2nd Dec 2006, 12:30 PM) <{POST_SNAPBACK}>
Hi and welcome Marco.
Why do you want to switch manually??????????
He may not, the second 'schematic' with switch may be just for those people who like things easily reversible.
You know... the anal-retentive.
It certainly would show a doubter of the air flap mod the difference!
#62 iz4dja
iz4dja
  • 30 posts
Posted 02 December 2006 - 05:52 pm
QUOTE(dandywarhol @ Sat 2nd Dec 2006, 05:30 PM) <{POST_SNAPBACK}>
Hi dandy,
if I put in my power commander one map with more fuel i need more air , so i can balance the mixture.
For instance, when i go for a long travel i put in a map for low consume, instead when i drive with my crazy friends i put in an acceleration map with more torque yeahyeahyeah.gif
Also , in Italy every two years we must go to motor-office for to check the pollution from exausth and more, so i can set-up original values on my bike.
I like to find the best set-up for my driving so in every while i can improve my set-up. good.gif
Edited by iz4dja, 02 December 2006 - 05:58 pm.
TDR900 ABS Grey metallic audi"iron jenny"
#63 dandywarhol
Posted 02 December 2006 - 06:59 pm
Hi Marco
I don't understand how the additional wiring circuit can alter the Power Commander - surely you need to set it up through the USB port???
I have a Power Commander fitted and find the airbox modification gives no difference to the way the engine drives - just more intake noise................
In fact, when I had the TPS replaced I refitted the airflap back to standard. It should have no effect on the emissions for a test whether the flap is open or closed.
#64 SteveGlover
SteveGlover
  • 857 posts
Posted 02 December 2006 - 10:03 pm
QUOTE(dandywarhol @ Sat 2nd Dec 2006, 06:44 PM) <{POST_SNAPBACK}>
Maybe they check that?
#65 wicklamulla
Posted 03 December 2006 - 02:53 pm
QUOTE(tdm850rider @ Sat 2nd Dec 2006, 05:31 PM) <{POST_SNAPBACK}>
You know... the anal-retentive.It certainly would show a doubter of the air flap mod the difference!
your a right wan you are !
Hi Marco
AE would that be a result of having yer engine tuned up so it over rides any negative effect the air flap may induce ???
#66 Pict
Posted 03 December 2006 - 02:56 pm
You have an electric disposal unit fitted, with gas bypass? - cool bionics! cool.gif
Edited by Pict, 03 December 2006 - 02:58 pm.
#67 dandywarhol
Posted 03 December 2006 - 10:53 pm
QUOTE(wicklamulla @ Sun 3rd Dec 2006, 03:38 PM) <{POST_SNAPBACK}>
Nah....I think the Power Commander sorts out the low speed fuelling pretty well - although the MAP I use is totally different to anything Dynojet produce - it was produced by the company which set the bike up on their dyno to suit the state of tune. I've got to say that the TPS change has sharpened up the low speed/mid range running much more..........it was running very rich towards the end - I gave it a handful on the rev limiter one time and Minty Hip was nearly asphixiated by the soot laugh.gif You should try it next time you're up here again - it's a different animal
#68 Spirit
Spirit
  • 77 posts
Posted 02 March 2007 - 11:58 am
I tried this one (easily done, thanks to good description) but I don't notice any big difference. May be there are less vibrations at ~2500 when throttling up, but it could be my own imagination. huh.gif
However, what happens with the emissions? Are there any facts?
TDM 900 ABS - 2005 (Diamond Black/Gold) SOLD!!
#69 Croc
Croc
  • 10 posts
Posted 09 April 2007 - 10:29 am
I have just read about the mod and tried it this am. I have to say that I noticed an immediate difference to the 'useability' under 4000rpm. Much smother and not nearly so 'snatchy'. If there is a small price to pay on fuel consuption - c'est la vie! banana.gif
#70 Matlock
Posted 09 April 2007 - 04:03 pm
After seven months of TDM ownership I finally cleared my backlog of SWMBO's DIY tasks and had some quality spannering time with my 900 today. Did the airbox mod - fantastic. 100% more rideable at low speeds. To prove it I went out & found a traffic jam (not too difficult today). Runs cleanly at very low speed, instant pick-up, no snatchiness. Why, oh why didn't I do this earlier? Next job, play with the CO settings.
#71 bilbob
bilbob
  • 26 posts
Posted 09 April 2007 - 05:00 pm
QUOTE(Matlock @ Mon 9th Apr 2007, 04:48 PM) <{POST_SNAPBACK}>
Hi all!
Just joined to add my appreciation for this mod. Performed yesterday during a bit of maintenance, and WOW! Immediate, clear difference!
Thanks a LOT!
#72 Geordie Guy
Posted 09 April 2007 - 06:34 pm
QUOTE(bilbob @ Mon 9th Apr 2007, 05:45 PM) <{POST_SNAPBACK}>
Hi all!
Thanks a LOT!
Same here,
Did the mod 1, and what a brilliant change.
Smooter and less vibration.
#73 Doc
Doc
  • 231 posts
Posted 09 April 2007 - 09:53 pm
Hi all!
Thanks a LOT!
Hi BB. Welcome to Carpe. Glad the mod worked so well. good.gif I'm sure you'll find lots more helpful hints and stuff on here.
#74 torbay
torbay
  • 8 posts
Posted 15 May 2007 - 07:48 pm
Instead of a switch why not have a little valve ????????? like the ones that control air flow in fish tanks ????
#75 wicklamulla
Posted 17 May 2007 - 11:03 pm
QUOTE(torbay @ Tue 15th May 2007, 08:33 PM) <{POST_SNAPBACK}>
why and what for ???
#76 danceswithmopeds
danceswithmopeds
  • 2,425 posts
Posted 18 May 2007 - 07:21 pm
To let the gas out of leathers with a quiet gentle hiss
#77 torbay
torbay
  • 8 posts
Posted 24 May 2007 - 07:27 pm
Earlier in this thread someone was on about electric switches and all that .................... My thought was that if you just make the pipe a bit longer and put an air control valve just under the front of the tank you can have it open or closed thats all "!!!!!!!!!!!
#78 wicklamulla
Posted 29 May 2007 - 09:18 pm
QUOTE(torbay @ Thu 24th May 2007, 08:12 PM) <{POST_SNAPBACK}>
mmmmmmmm i might fit one of those to the missus.
#79 Pict
Posted 29 May 2007 - 09:44 pm
QUOTE(Croc @ Mon 9th Apr 2007, 11:14 AM) <{POST_SNAPBACK}>
Never found any change in the consumption - nothing negative, anyway
#80 Peter Watts
Peter Watts
  • 61 posts
Posted 06 June 2007 - 08:00 pm
QUOTE(Baron @ Wed 4th Oct 2006, 01:11 PM) <{POST_SNAPBACK}>
Just done the air box mod on my 2004 TDM900, see http://jbx9.free.fr/...x...=AIR&lng=en
The on/off low speed throttle response has all but gone, bottom end torque has increased and the engine is just so much more usable between 2000 and 3000 rpm. Fantastic...it feels like a new bike!!
If you've gotta 900 and haven't carried out option 1 referenced in the link above....do it....you won't be sorry laugh.gif laugh.gif laugh.gif
Hi there,
I have just bought an '05 900 and would like to do this mod. I find my bike to be very snatchy at low revs, annoyingly so. Can I get an English translation of this mod? Is it easy to do? I want to take the tank off to fit a Scotoiler anyway. Many thanks Peter, Derby UK
