Overrun Fuel Cut Defeat Device
49 replies to this topic
#41 samotomas
samotomas
  • 3 posts
Posted 24 October 2024 - 10:51 am
So, what are your final results? Grounded ECU wire too, but on my TDM there is not so much effect. I got less engine braking on 4, 5, 6 gears, but thats it. Throttle on/off efect still going on.
Airbox flap fixed, CO setting adjusted for more open exhaust already.
#42 fixitsan
  • 4,839 posts
Posted 24 October 2024 - 07:22 pm
Thats it, thats what I wanted.Even in third I find there's less braking, which is great as far as I'm concerned. I also have the flap disabled,
I've just added a relay so that when the brake light comes on I get full fuel cut/engine braking
I don;t find the throttle to be on-off , I think it feels like I hoped, like it is running on carbs
#43 Favs
Posted 25 October 2024 - 11:39 am
I gotta compare ABS wiring with non-ABS diagram at some point.
#44 fixitsan
  • 4,839 posts
Posted 25 October 2024 - 02:53 pm
Crude but correct wiring diagram !
Attached File  relaybrake.jpg   70.9KB   0 downloads
#45 thong
thong
  • 67 posts
Posted 30 October 2024 - 09:00 am
quick question, does using a high tickover as recommended by JBX (1400) have any effect on engine braking/fuel cut
#46 fixitsan
  • 4,839 posts
Posted 30 October 2024 - 12:53 pm
Hi
No I don't think it makes any effect. What've noticed when decelerating is that coming down in revs to a value between 2000 and 2200rpm the fuel cut effect ends automatically. It seems like fuel cut only happens above and around that figure, below that value there doesn't seem to be any cutting.
It's got to be very similar, I would have thought
#47 Favs
Posted 03 November 2024 - 09:40 am
Yes Chris,  from my initial comparison they seem the same - I'm just starting a big (and final (hopefully)), contract so my bike-fiddling time is limited until mid 2025 at the earliest. :waiting:
#48 fixitsan
  • 4,839 posts
Posted 04 November 2024 - 08:54 am
That sounds like a very comprehensive contract. May it bring it's own rewards :good:
#49 thong
thong
  • 67 posts
Posted 12 November 2024 - 08:35 am
as an alternative use for your device why not use it to add fuel between 1500 and 3000 revs, this will cure everyones stutter :good:
#50 fixitsan
  • 4,839 posts
Posted 12 November 2024 - 01:18 pm
I did actually think of that too, but my bike came with a Power Commander which already does this, and I know a lot of others have PC's already.
I found that advancing the ignition timing a few degrees also helped
