Multi-Shock Adapter For Tdm 900
28 replies to this topic
#21 Kebab897
Kebab897
  • 58 posts
Posted 04 November 2024 - 03:55 pm
So the R6 shock worked fine (for me) with the 650lb spring fitted (12.5 stone rider).
Next up was the longer 2010-2011 BMW S1000RR shock.
I removed the R6 shock, took off the heavier spring, rearranged the spacers on the top clevis & transplanted the 650lb spring onto the S1000RR shock & finally fitted it.  I had to the crank the preload right up to get it close to the right ball park sag for me: not sure why this is the case - different internal damping from the other shock, or is the length of the shock also a factor?
Anyway, after some initial testing, I decided to fit a heavier 700lb Faulkners spring to it instead (not enough room to use the TDM's spring).  A 675lb spring would probably also be fine, but I couldn't find a cheapish one available when I went looking.
This worked well for me.  Of the two shocks tested so far, I actually prefer the BMW one although difficult to articulate why - somehow the rebound 'feels' slightly better.
Pics to follow.
#22 thong
thong
  • 68 posts
Posted 08 November 2024 - 02:04 pm
do the different shocks effect the amount of travel
#23 Kebab897
Kebab897
  • 58 posts
Posted 12 December 2024 - 07:14 pm
Apologies for delay in responding.
Yes, the shocks I'm using are from sportsbikes which have less travel than the standard TDM one.  Mine however is never used off-road, has a 17 inch front and also have the forks up through the yokes, so happy to do without the extra travel at the back.
I may have over-estimated the spring rate slightly and probably shoulda went with a 675lb spring for my weight, but it still feels great.
Hmm, not sure if images can be seen?
https://ibb.co/tQ5LX4s
https://ibb.co/ckxDPFm
Next - the third and final shock to install: GSXR 600 / 750
Edited by Kebab897, 12 December 2024 - 07:15 pm.
#24 dapleb
  • 18,376 posts
Posted 12 December 2024 - 10:18 pm
Images worky
#25 fixitsan
  • 4,842 posts
Posted 16 December 2024 - 03:52 pm
Looking good, it's great to have all these alternative upgrade options
#26 Kebab897
Kebab897
  • 58 posts
Posted 19 January 2025 - 06:52 pm
So unfortunately I've had to abandon this little alternative shock project and have been forced into something else to allow me to continue riding, will be posting a separate thread about this.
But for anyone who may be interested in the future, it was my intention to fit a Suzuki GSXR 600 / 750 shock, K6-L0 models (years 2006-2010). Dimensions appear quite similar to the above BMW shock and I believe it would've fitted the adapter with fairly minimal alterations needed.
#27 fixitsan
  • 4,842 posts
Posted 20 January 2025 - 04:31 pm
Looking forward to reading about it.
I might also be posting about new wheels, an FJR1300, it's really tempting me !
#28 leehenty
  • 5,316 posts
Posted 20 January 2025 - 07:22 pm
No worries about the final drive then, like a BMW.
Edited by leehenty, 20 January 2025 - 07:27 pm.
#29 fixitsan
  • 4,842 posts
Posted 23 January 2025 - 09:46 pm
No I hear they're very reliable.
I would still keep the TDM I think, if it will squeeze in the garage
